Cant Hook At All Help
Old Nov 18, 2007 | 09:25 PM
green96ta's Avatar
i put a new zexel torsen diff in to replace the badly slipping auburn unit. just before that i put on the control arm relocation brackets, that paired with nittos finished off the auburn. well now that i have a non-slipping differential i cannot hook at all, i cant go over half throttle from a start without roasting my tires. and if i stomp it from a stop it will walk side to side untill i hit 50-55. this is on street tires, but i should hook better than that with those brackets. what can i do to my suspension to make it hook? mods in sig
Old Nov 19, 2007 | 08:03 AM
Greed4Speed's Avatar
Which Nittos?
Old Nov 19, 2007 | 08:52 AM
green96ta's Avatar
not sure
im not sure, but i only used them at the strip that one time. on the street with street tires, theres no hope for hooking
Old Nov 19, 2007 | 09:08 AM
Z-RATED94's Avatar
Why not go out to the car and take a look? Did you purchase these, or did they come on the car when you bought it?
Old Nov 19, 2007 | 09:38 AM
green96ta's Avatar
oops
i thought that i put that they are my friends tires in the first post. thats completly my fault. they are my friends nitto drs. ill find out what they are. does anyone know how i can hook on street tires in the mean time?
Old Nov 19, 2007 | 12:29 PM
If they're DR's then that tells what Nittos they are.
OK, did you heat them? Soft tires pick up a lot of grit. You need to spin them to clean them and a bit more to heat them up.
I also see that you have Sportlines. Those set too low. If you look, your LCA's are probably still not at a good angle.
Old Nov 19, 2007 | 08:38 PM
green96ta's Avatar
hmm
so i need to find someway to lift it a little?
Old Nov 19, 2007 | 08:53 PM
Get rid of the Sportlines. They weren't built for drags or really for handling since they don't have enough rate in the rear for how low the set. They're really only good for looks if you like the car to be that low.
Actually, if you have a friend with stock rear springs or something taller, you could slap them in and see if that helps.
Old Nov 19, 2007 | 10:20 PM
green96ta's Avatar
hmm
guess ill try to put some of them little lifter things in the springs.
Old Nov 20, 2007 | 08:32 AM
Z-RATED94's Avatar
Don't do that, there garbage.
Old Nov 20, 2007 | 08:56 AM
danhr's Avatar
ditch the lowering springs.... put a set of v6 springs on instead
play with the settings for your lca relocation brackets..... most of the time the bottom one performs the best, but sometimes it doesn't.
invest in either a new set of rear shocks (do a search to find the ones that suit your needs) or a set of lca's. Those would be your best bang for buck traction mods.
that and a nice set of tires for the rear..
Old Nov 20, 2007 | 09:25 PM
Just get some taller springs and try it.
KYWes
Jun 14, 2022 06:52 AM
jackpawt883
Sep 10, 2015 08:53 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
canuck94z28
Aug 19, 2015 05:50 PM
jwade88
Jun 14, 2015 09:38 PM
