Wheels Wheels Wheels
Old Sep 21, 2012 | 04:36 PM
40Al's Avatar
I just bought a set of 2000 Camaro wheels for my '94 Z....and they wobble.
Are there different offsets or back spacing...from front to back...
Or did I just throw money away?
Old Sep 21, 2012 | 08:51 PM
Kevin Blown 95 TA's Avatar
Re: Wheels Wheels Wheels
You might have interference with the hubs. You might need to slightly dremel the ID of the wheels to fit over the hubs, Not sure if that is your prob, but check that first. I seem to remember something along that nature with retrofitting wheels.
Old Sep 22, 2012 | 06:22 AM
alex-z28's Avatar
Yeah, you are right.
That's the problem I had when I installed 02 SS wheels on my 93 z28, it was only the rear wheels I had make inside ID bigger, front wheels fit good.
Check your rear wheels, I did same thing. I put the wheels on and torqued the crap out of it only to find out that wheel was not sitting tight against the wall (or whatever that's called), had hell of a time getting that wheel off.
Old Sep 22, 2012 | 07:15 AM
parkers Z28's Avatar
Shoebox has a something about this. you need to look at his Sig. tech page. (how to)
Old Sep 22, 2012 | 08:32 AM
We have a "Wheels and Tires" forum and this topic is covered in the FAQ. As noted the rear axle hubs are larger than the front hubs through the 96 model year. In 97 they made the rear hubs smaller to match the fronts and made the hub hole in the wheels smaller.
Hopefully you didn't tighten the wheels down with excessive torque. The wheels may be very difficult to get off any may have fractures at the hub holes.
force10
Aug 10, 2015 08:30 AM
30th Anniv Z28
Aug 1, 2015 10:39 AM
240ssLs3
Jul 13, 2015 05:06 PM
Slayer
Jul 4, 2015 03:06 PM
fryguy
Jul 29, 2002 08:16 AM
