Whats my problem?
Sway bar end link bushings are most likely worn out. Go to your local auto parts store and ask for four new sway bar end links bushing kits and replace them. I am almost positive that's your problem.
You could just get under your car and look at them as well. If you have never changed them out nor did anyone who owned the car before you and it's still on the stock end links there will most likely be no bushing left and you will just see the stock plastic bump stop type things where there should be a bushing.
Magenta_Hearts
Mar 25, 2015 10:24 AM
