What is that thumping sound???
Old May 19, 2006 | 07:47 AM
wrd1972's Avatar
I noticed on the way to work today I have a loud dampened thumping noise when I hit rough spots in the road. It also did it on a big speed bump too.
The thump occurs many times in one occurance depending on how bad the road is. It sounds like the left side but I can tell if its from the front or rear. It sounds like its under the seat.
Can someone point out what the most likely causes of this might be, I will jack it up tonight to investigate.
Old May 19, 2006 | 12:47 PM
kaell's Avatar
Re: What is that thumping sound???
Same problems too... Clunks on speedbumps and rough road.
Anyone?
Old May 19, 2006 | 01:42 PM
spartyon's Avatar
I had that happen in my Taurus and it needed new tierods.
Old May 21, 2006 | 09:12 AM
jkucz31's Avatar
how many miles???? I have the same noise too but started after my subframe install, rear control arm bushings....
Old May 21, 2006 | 09:14 AM
kaell's Avatar
Mine has done 38000 miles... just in the front.
Old May 25, 2006 | 08:15 AM
RENE95Z's Avatar
Check your tranny mount. You can't always tell if it is broke by just looking at it. You have to get up under the car and push up on the driveshaft about a foot behind the mount towards the rear of the car.
PopoFormula
Oct 12, 2015 04:19 PM
4586
Sep 27, 2015 01:55 PM
autoxr166
Sep 25, 2015 04:21 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
