What should I torque my calipers at?
Old Mar 9, 2005 | 02:03 PM
Meccadeth's Avatar
I'm replacing my front calipers today...what torque should I "bolt" them in at?
Old Mar 9, 2005 | 02:27 PM
Bone Daddy's Avatar
Re: What should I torque my calipers at?
That info and all the other specs can be found here.
I've used this for a while, to Mr. Franker.
Old Mar 9, 2005 | 03:37 PM
Meccadeth's Avatar
Do they have any info on a '99 Z28? Or should it be about the same?
Old Mar 9, 2005 | 07:49 PM
Bone Daddy's Avatar
I am in the mindset that they should be torqued the same. After all thr two calipers aren't really all that different. I'll check my Haynes manual for the 99's actual spec's though.
[edit]
Well, I was wrong they should be torqued at 23 pounds instead of the 38 pounds listed for the pre-97 models.
Hope this helps.
Old Mar 10, 2005 | 09:18 AM
Compstall's Avatar
I use my elbow torque-o-meter.
Old Mar 10, 2005 | 12:13 PM
Patrick96Z28's Avatar
yeah, tighten until you lose circulation and just before you strip threads.
Jake Bialke
Sep 24, 2015 11:31 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Henson071
Sep 18, 2015 04:01 PM
Bxlt1
Sep 17, 2015 08:31 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
