What Next? After Prokit install.
Old Nov 9, 2007 | 04:09 PM
95zsean's Avatar
I just finished installing my ProKit and a new set of DeCarbons for a 97(got a great deal on the shocks from a member).I know it's not the best combo but it was a good deal.
What else do i need to do? I've read that you need a adj.torque arm and then I 've read that I don't with the Prokit.
Old Nov 9, 2007 | 04:44 PM
rexcellent's Avatar
You will need to get an adjustable panhard bar to re-center you rear axle. Also, if you want to have any traction, you will need to get some lower control arm relocation brackets as well as some adjustable lower control arms.
Old Nov 9, 2007 | 07:36 PM
95zsean's Avatar
My rearend is still centered!!! I checked. What I'm wondering is if I've changed the rearend angle with only 1.3 inches of drop in the rear? Also should I get the car lined up? If so, should the shop use the orignal numbers or is there some other ones that are better?
Old Nov 9, 2007 | 09:42 PM
Z-RATED94's Avatar
If the car is still centered, that's good to hear. The relocation brackets would be nice, and an adj. TA to re-set your pinion angle. I used a Spohn tunnel mounted piece, and set the angle to negative 1 1/2.
Old Nov 10, 2007 | 08:09 AM
95zsean's Avatar
To check the angle you have too have the car on a wheel hoist that's level. What is an exceptable angle?
Old Nov 10, 2007 | 10:55 AM
Z-RATED94's Avatar
Negative 1.5 degrees is what I run. Helps at the track and tame enough for the street.
Old Nov 10, 2007 | 12:22 PM
............ Also should I get the car lined up? If so, should the shop use the orignal numbers or is there some other ones that are better?
Are you asking if the front wheels need to be realigned? If so, the answer is yes. The stock specs are not necessarily the best for lowered cars. There are some recommendations in the 4th Gen FAQ which seem to be consistant with what I did when I was running the Pro-Kit.
http://www.f-body.org/faq/4/4_5.htm#ch4_5c
Old Nov 10, 2007 | 06:16 PM
95zsean's Avatar
Are these Spec. the ones that you used?
Old Nov 11, 2007 | 10:09 PM
Close. +4.0 Caster, -1.0 Camber, 0.1 toe
Old Nov 12, 2007 | 10:47 AM
95zsean's Avatar
And you never had a problem with tire wear? I have ZR1 17X9.5 all the way around.
Old Nov 12, 2007 | 05:02 PM
Never a problem with tire wear. 17x9.5 front/17x11 rear.
Old Nov 12, 2007 | 07:15 PM
95zsean's Avatar
Thanks for the info. It will be the first thing I do when I get it out in the spring.
Old Nov 14, 2007 | 10:48 AM
94Z28rag's Avatar
I have had the same wheels and tires and Pro-Kit for over 2 years and I've never had treadwear or traction problems ever.
Old Nov 16, 2007 | 06:18 AM
95zsean's Avatar
So you used the same numbers for the line up? Also what else did you do to your car's suspension?
Nice looking Vert.
Old Nov 26, 2007 | 11:13 AM
94Z28rag's Avatar
Nice looking Vert.
Thanks. I have Koni shocks in the front and stock shocks in the rear as of now. The springs were all I ever did suspension-wise...I just wanted it lower.
The ZR1's are 17x9.5 with 275/40/17s tires on em.
CARiD
Jul 7, 2015 08:19 AM
kmk7110
Jun 20, 2015 05:53 PM
Jeff'SS
Jun 1, 2015 06:21 AM
BigWil
Mar 29, 2015 12:24 PM
TechnoThief
Nov 22, 2002 05:05 PM
