What Next? After Prokit install.
I just finished installing my ProKit and a new set of DeCarbons for a 97(got a great deal on the shocks from a member).I know it's not the best combo but it was a good deal.
What else do i need to do? I've read that you need a adj.torque arm and then I 've read that I don't with the Prokit.
You will need to get an adjustable panhard bar to re-center you rear axle. Also, if you want to have any traction, you will need to get some lower control arm relocation brackets as well as some adjustable lower control arms.
My rearend is still centered!!! I checked. What I'm wondering is if I've changed the rearend angle with only 1.3 inches of drop in the rear? Also should I get the car lined up? If so, should the shop use the orignal numbers or is there some other ones that are better?
If the car is still centered, that's good to hear. The relocation brackets would be nice, and an adj. TA to re-set your pinion angle. I used a Spohn tunnel mounted piece, and set the angle to negative 1 1/2.
http://www.f-body.org/faq/4/4_5.htm#ch4_5c
Are you asking if the front wheels need to be realigned? If so, the answer is yes. The stock specs are not necessarily the best for lowered cars. There are some recommendations in the 4th Gen FAQ which seem to be consistant with what I did when I was running the Pro-Kit.
Nice looking Vert.
The ZR1's are 17x9.5 with 275/40/17s tires on em.
CARiD
Jul 7, 2015 08:19 AM
