Well My Brake Booster Is Leaking Now What (pics Inside)
Old Nov 9, 2006 | 09:54 PM
playa7970's Avatar
just noticed the leak today where can i get a replacment and could this be causing me to loose vacuum?
Old Nov 10, 2006 | 02:27 PM
OBE1 95Z28's Avatar
Your master cylinder is leaking, not your brake booster (vacuum canister behind the master cylinder). I bought a replacement master cylinder from my local parts store about 2 years ago for approximately $50. They rebuild the cast piece with new seals. You transfer your existing plastic reservoir over to the rebuilt casting. You'll need to "bench bleed" the master cylinder before bolting in on to the car and then bleed your brake lines.
Old Nov 10, 2006 | 04:25 PM
playa7970's Avatar
thank you for the clearing that for me is this going to be a pita? and is it easy to bleed the lines?
Old Nov 10, 2006 | 05:23 PM
OBE1 95Z28's Avatar
It's a straight forward change as long as you use line wrenches for the brake line connections, perform the bench bleeding of the master cylinder, and bleed your ABS module as well as the brake lines when your done.
Magenta_Hearts
Mar 25, 2015 10:24 AM
WildRidez
Feb 23, 2015 07:24 PM
Queens94z28
Dec 20, 2014 09:11 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
omarECD
Aug 19, 2002 07:28 AM
