weird problem with abs inop
Old Oct 23, 2009 | 10:40 PM
Drew24's Avatar
Ok so just washed my car abd the abs inop goes on and the track light and brake light starts flashing. So when I got home I herd a huge ticking noise under the hood where the relay is so I took the relay off and it stopped drove to an auto part store too get a new relay. I changed the relay and the lights go off except the inop. Drove it around and thn the brake light came on please help I'm stumped
Old Nov 9, 2009 | 01:40 PM
tlillard23's Avatar
water in the ABS wheel sensors? did it go away after things dried out? maybe you knocked one of the sensors looooose when washing..?
Old Nov 9, 2009 | 02:24 PM
flexus's Avatar
Here's what I just found on my '96 Z-28 with Pacesetter LTs.
The passenger side header worked it's way through and burned one of the wires of the ABS sensor on that side.
That's what caused my ABS INOP to trigger recently...
Old Nov 9, 2009 | 04:12 PM
Drew24's Avatar
Thanks that makes since i have been doing alot of work on that side cause i have been burning through plug wires. Were did you notice that at and was it clear to see or did you have to take the alternator off
Old Nov 9, 2009 | 04:22 PM
flexus's Avatar
Well the ABS wire runs on the wall of the wheel well right past the out most header tube. And right where it's closest the jacket was burned crisp and the wires were definitely affected.
I noticed it after taking the engine out of the car to put on some LE2 heads and stuff, but the ABS INOP thing had just started happening like 1 week ago.
Old Nov 10, 2009 | 08:16 AM
Drew24's Avatar
How was the light going on cause whats been happening is if the car is sitting they all go off once i start to drive the inop goes on and the brake and track light comes on and starts twitching like going on and off but not flashing it seems like there is a short some where but i haven't had time to check it because i have been working alot. Do you know any troubleshooting methods i can do to check to find the problem
Old Nov 10, 2009 | 08:35 AM
flexus's Avatar
You can try to check for error codes first, then you better start looking under the hood for burned wires...
My ABS INOP light just comes on and stays like that, no other lights come on.
Also I'm thinking look for brake fluid level and maybe have the whole brake system bleeded... maybe some bubbles in the ABS block are causing the commotion.
Good luck!
Old Nov 10, 2009 | 09:16 AM
Drew24's Avatar
Alright thanks for the help
Old Nov 13, 2009 | 02:01 PM
Drew24's Avatar
Ok i discovered the short I thought it might have been a sensor but the short is at the abs relay i changed the relay and it kept happening so i kinda started messing around with the fuse box and it stopped ticking and the lights went off .But every time i stopped touching the wires it would come back on and start flashing and ticking again. What should i go about this i have no idea what to do any suggestions would be appreciated
jj_burchiel
Mar 21, 2015 12:51 AM
dluna333
15
Mar 13, 2015 12:30 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
97z28k&N
Jan 9, 2015 04:58 AM
Black Sunshine/ 00SS
Aug 24, 2002 03:41 PM
