upgrade for roadracing
Old Jul 9, 2008 | 04:31 PM
  #16
Chewbacca's Avatar
Originally Posted by Sam Strano
Wow, Korry has learned well.....
Now if only I could learn to drive....
Old Jul 9, 2008 | 04:44 PM
  #17
Sam Strano's Avatar
Move back to PA and I'll see what I can do.
Old Jul 10, 2008 | 05:30 AM
  #18
ralf's Avatar
Originally Posted by slomarao
Next would be a vette setup, but it would require you to run a 17 inch rim in the front. Also with either of the 2 upgrades there are a lot more choices as far as pads and rotors. So your choices arent so limited.
So if you go with the better vette setup and than pick out some high quality pads and rotors your going to notice a night and day difference.
This make sense??
I already run 17" rims and have excellent front brake setup (13" Movits).
Vette setup for rear - is it direct swap or some machining required?
Old Jul 10, 2008 | 11:14 AM
  #19
Sam Strano's Avatar
Ralf, you are way light on camber, and a bit on caster too. You need camber for grip, and it's hard to get too much. I run -1.8 and would like to get to -2, but can't under the rules I have to abide by and the ride height I run. -.4 is nothing, even -1 would help front grip a ton.
13qtr
Oct 28, 2016 08:11 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Tarizza
3rd Gen / L98 Engine Tech
Sep 20, 2015 03:26 PM
97SSdude
Aug 21, 2015 09:36 AM
