Traction
Re: Traction
spend the 700 on phr, lca, and torque arm...then buy stickeys...you should be in the 1.9-1.8 with that. surprisingly i had a 1.9 with all factory. was this with a corrected time or not?
Re: Traction
Some sticky tires will make the biggest difference.
I have an Eibach drag launch kit and LCAs, PHR, BMR relo brackets and an adjustable TA and along with 275 Nitto drag radials it solved my traction problems.
Start with the LCAs and then the relocation brackets, they helped the most on my car.
Javi Fierros
Jun 10, 2015 03:35 PM
