LS1 brake swap...just front????
I need install guides.....and what i need as far as parts when i go to the junk yard......i mean do you just take the rotors, calipers....or master cylinder to...any info would help thanks
Re: LS1 brake swap...just front????
auright thanks guys....those links really helped visualize what i need when i go to the salvage yard....it's a lot bigger ordeal than i thought it was gonna be...but i think it can me done w/me and my dad in a weekend
so you guys just did the front correct???
there's a big difference in the area size of them...i wasn't aware of that big of a difference
how much should i look to pay for both the front's in a salavage yard....i have no idea so shoot me a price b/c i don't want to get took
btw...will these work with lowering springs??
Yes i did the fronts only. Most people only do the fronts because the rears really aren't much better than what you have. People lower their LS1's so i don't think it should be a problem on your car. Its not that big of project. It took me 4 hrs working by myself start to finish including a trip to the parts house.
Just go to ebay and check around there for a complete "kit". I've seen a few sell for $150 lately. So, you shouldn't spend more than $200 to get it shipped to your door.
oh one more thing guys
does the abs still work with no light on the dash.......do you have to get reprogrammed or anything or will it just plug right up w/o any other tuning......b/c i have the ODBI conversion pc in my car
sorry to clarify i meant.....i didn't want the abs light to stay on or somthing from not getting it programmed for the ls1's.....i wasn't aware that the sensors would be the same thus i thought it might trip the light on the dash
and again any year 98+ on camaro or ta will work right?
Speed sensors in the spindles are the same, i'm running front brakes off a 98 ss and haven't had any problems. You can knock them off in an hour or two if you know what you're doing and don't run into any problems. When i put mine on my lower ball joints on both sides needed to be changed, other than that it was really simple. You'll also need a brake bleeder tool if you don't have one, and it's a good idea to get new crush washers(you'll need 4).
okay thanks alot guys.....yeah i'm gonna drop it an inch while i've got all this apart so i was aiming to align it anyways then
so how do you tell if the ball joints need replacing...if there's play in the front spindle or what??
what's crush washers...maybe we call them somthing diff. but im not familiar with that term i don't think
The ball joint will seem really sloppy and move easily if they're worn out.
mine had 70k and were shot, it's not really hard to replace them. I'd definetly recommend doing it while you're down there if there's any signs of wear. They're only like 25 bucks for a new set from autozone and they rent the tool for free. The problem with mine was the i couldn't tighten the castle nut back on without the ball joint spinning. Only takes about an extra 30 minutes to do, no big deal. Crush washers on the copper washers that go on the line were it connects to the caliper, definetly want to replace these or your breaks will leak.
