Torque specs(ft pd) for sphon TA bolts
Old Aug 11, 2006 | 12:17 PM
always faster's Avatar
Ok im still searching to find my noise/vibe problem on my car,its like a mystery problem that even "qualified" shop couldnt find it...
I want to check if the bolts of my sphon adjustable torque arm are at the good torque specs(foot/pound).
What i know:
-The 2 rear one that connect to the diff housing are rated at 90 ft/pd
-The 4 small one(8mm i think) that hold the tunnel brace or g-load brace are rated at 30 ft/pd
But what about the big one on the tunnel brace,the one that play the role of the swivel?
And the other big one that is at the end of the TA that hold the poly bushing?
I need accurate answer please because it as been 1 1/2 year that i investigate on that problem and loose bolts could be my problem.
Thank you
Old Aug 12, 2006 | 12:20 PM
Re: Torque specs(ft pd) for sphon TA bolts
Someones gotta know this Im not the only one whos running this TA
Old Aug 14, 2006 | 06:56 AM
bring this to the top
Old Aug 15, 2006 | 12:32 PM
"White Knight"'s Avatar
I believe that is also 30ft-lbs maybe a little less. You are suppose to be able to swivel it. In the instructions it is very vague and doesn't exactly tell you.
maybe2fast
Mar 16, 2015 09:45 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Wicked
Jul 7, 2003 01:28 AM
Wicked
Aug 22, 2002 12:37 PM
Wicked
Jul 29, 2002 04:17 PM
