torque arm questions
Old Feb 9, 2010 | 10:13 AM
1995camaro Z-28's Avatar
I bought a 1995 Z-28 set up with a Jasper Crate Engine LT-1 350 bored 30 over,headers,racing clutch,k&n cold air induction,flowmaster thunder 3in exhaust,eldebrock torque arm from tranny to rear end.My question,on rough road car feels like rear end is being pulled off the road.It it because of torque bar?
Old Feb 9, 2010 | 01:39 PM
If it bolts/mounts to the stock locations, there shouldn't be any diffence at all in the way it controls the rear axle. Its a bit stiffer than the stocker, but the stiffness is only a factor when there is huge torque applied to the rear wheels.... not going over bumps.
Have you checked the pinion angle to make sure it hasn't caused any large (unintended) change?
Old Feb 9, 2010 | 02:58 PM
koolaid_kid's Avatar
You might want to check the rear end alignment left-to-right. Many come from the factory with the rear offset to the passenger's side by an inch or more. An adjustable panhard bar would correct this if present.
Old Feb 10, 2010 | 01:44 PM
thanks for your help i'm new to this areai have only had stock camaro's in the past
1995 camaro Z-28
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
canbaufo
May 5, 2015 03:43 PM
Jason Short
Jan 19, 2015 06:34 PM
87Aerocoupe
Jan 10, 2015 07:27 PM
