thump over bumps
Old May 24, 2005 | 01:24 PM
lhugrad03's Avatar
thump over bumps
when i go over certain bumps, there is a thump on the front passengerside it feels like it is by the shock. what are some causes of this? thanks
Old May 24, 2005 | 02:11 PM
a327vette's Avatar
Re: thump over bumps
Sounds like maybe a worn out control arm bushing or maybe even a tie rod end or ball joint. Go out and start yanking around on the front wheels and see if they move any. If they do, look to see where the movement is coming from.
Old May 24, 2005 | 02:16 PM
lhugrad03's Avatar
should i jack the car up first and then try to jerk the wheel around? if the wheel does not move what could it be? thanks
Old May 24, 2005 | 04:27 PM
a327vette's Avatar
jacking the car up will help you alot. If there is no movement anywhere....uhh...well...it must be something else.
Try getting someone to drive the car over a bump while you walk next to the car. You should be able to tell a little closer where it is coming from. Just dont get ran over.
Old May 24, 2005 | 05:15 PM
taguy001's Avatar
also check for a broken sway bar link
Old May 25, 2005 | 06:33 AM
lhugrad03's Avatar
thanks guys
Jeff1904
Jun 5, 2016 05:00 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
BLK1997Z28
May 2, 2015 01:26 PM
natZ
Sep 16, 2002 04:47 PM
LT1Thunder
Advanced Tech
Jul 11, 2002 10:17 PM
