Are there any alignments to be done on the rear?
Old Mar 13, 2006 | 12:22 PM
madwolf's Avatar
I'll be taking my car for a custom alignment pretty soon. I was wondering if there is any alignment to be done in the back. I would think not considering it's a solid axle, but just thought I'd ask anyway.
Thanks.
Old Mar 13, 2006 | 12:36 PM
Re: Are there any alignments to be done on the rear?
There are no provisions for adjustment on the stock rear suspension. If you have an adjustable panhard rod, they could insure the body is centered correctly side-to-side over the rear axle assembly. And if you had adjustable LCA's, they could insure that the rear axle assembly is perpendicular to the longitudinal axis of the car (thrust angle). Otherwise, you are stuck with whatcha got.
Old Mar 13, 2006 | 01:06 PM
Camaro_Maniac63's Avatar
You could technically drop the axle and bend the axles just a bit to get some negative camber in the rear, but I don't think the alignment shop will want to do that
http://www.frrax.com/rrforum/index.p...egative+camber
Old Mar 13, 2006 | 02:46 PM
wrd1972's Avatar
Better consider some flexible axles for the rear camber adjustment. Its gonna look a bit rice too.
oldschool
Feb 9, 2016 09:21 PM
achipfef
May 5, 2015 10:20 AM
Hurin
Dec 13, 2014 07:38 PM
Wilson
Jul 21, 2002 05:08 PM
