Terrible wheel hop!
Old Apr 11, 2007 | 09:02 PM
Camaro350z28's Avatar
Terrible wheel hop!
I have a nasty wheel hop when turning right and then giving it just a little gas.. its like the car wants to break loose over nothing at all but just starts hopping real bad and shaking my interior loose haha
Know what could be causing this? tight suspension in back or something off?
Old Apr 12, 2007 | 09:22 AM
OBE1 95Z28's Avatar
Have you ever changed the differential fluid? If yes, did you add the Limited Slip additive?
Old Apr 12, 2007 | 09:35 AM
no i have not.. pretty messy to do? where do i get the stuff at? gm dealership?
Old Apr 13, 2007 | 03:07 PM
OBE1 95Z28's Avatar
If you have the original fluid, chances are that's not causing your wheel hop. Did you lower the car?
Old Apr 13, 2007 | 03:12 PM
yeah i have it lowered with hotchkis springs.. also have hotchkis lca's and koni adjustables all the way around... i dont have wheel hop in a straight like just on corning.. and only have to mildly push on the gas
Old Apr 13, 2007 | 05:41 PM
Ryatt-SS's Avatar
You might have a worn transmission mount, or you may need to invest in an adjustable torque arm.
Old Apr 13, 2007 | 07:20 PM
energy suspension tranny mount... never thought of tryin the torque arm.
Old Apr 14, 2007 | 06:01 PM
OBE1 95Z28's Avatar
Lowering a car changes the rear suspension geometry and promotes wheel hop, although you usually feel it with straight line action. LCA relocation brackets allow you to correct the geometry.
Old Apr 15, 2007 | 01:07 AM
Z-RATED94's Avatar
It helps, but with a lowered car the pinion angle has most likely been changed. A quality adjustable TA would help also. One with the crossbrace instead of one that still mounts to the trans would be a nice inprovement.
Old Apr 15, 2007 | 07:30 PM
ok i will get those relocation brackets... could a adjustable panhard be in order perhaps? looks like the rear is shifted just slightly towards the passenger side?
Old Apr 15, 2007 | 09:19 PM
Z-RATED94's Avatar
Yes, and an adjustable TA will help as I mentioned. World of difference if you want some straight line traction.
Old Apr 15, 2007 | 11:48 PM
TobyZ28's Avatar
Have you considered your rear aftermarket LCA's are binding? (im assuming they're poly).
Old Apr 16, 2007 | 01:23 AM
yeah i dunno was just baffling me.. i guess i can get underthere and check everything again.. and the adjustable tq arm and panhard are definitely not going to hurt anything, also the relocation brackets.
Flint78
Jun 21, 2015 01:28 PM
maybe2fast
Mar 16, 2015 11:59 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
SAR2K
Sep 1, 2002 10:49 AM
wytblur
Aug 5, 2002 02:03 PM
