Swaybar Install help?!?
Old Oct 15, 2006 | 11:01 AM
ls1powerz28's Avatar
I had purchase a swaybar package from Strano, and had them installed by a local shop. 35mm/21mm. I watched and helped with the install, but when this guy installed it, he said that I didnt need any grease. I saw on the installuniversity that you have to grease the "D" bushings. If this isnt greased, will it cause more noise and less performace in any way? Should I just jack the car up and unmount it and grease it myself?? Thanks in advance. Btw I have a 2001 Z28 with new shocks, SFC, STB, and PHR. (if this helps)
Old Oct 15, 2006 | 11:55 AM
2000GTP's Avatar
Re: Swaybar Install help?!?
I would just grease them. I don't understand why they skipped over it in the first place. It takes so little effort to tear open a little package of grease and apply it to the bushings before putting on the swaybar.
Old Oct 15, 2006 | 12:34 PM
Hopefully you didn't pay them a whole lot for doing the install, and not doing it correctly. All the more reason to do the work yourself, particularly something really simple like sway bars.
Old Oct 15, 2006 | 01:12 PM
BadgeZ28's Avatar
aftermarket sway bars usually come with urethane style bushings. A special tube of lube is also usually included to grease the D shaped bar bushings. It is a semi clear lube.
Old Oct 15, 2006 | 01:35 PM
Bud M's Avatar
If you don't grease them, the bushings will grab tight to the swaybar. They are not meant to do that. Grease them and periodically re-grease them (at least once a year).
Old Oct 15, 2006 | 04:16 PM
Yeah I really didnt pay much to have them do it. I should have done it myself. I got Marine Grease which was recommended on another thread. i hope this stuff works great. When i re-grease them, do I have to completely remove the "D" bushing off the bar and grease them? Thanks for the info and it just shows how certain business fail do to stupid mistakes..
Old Oct 15, 2006 | 04:36 PM
al 96 Ram Air T/A's Avatar
Yup...pull the bushing (that thing your refering to as the D-ring). Put a nice coating of grease, preferrebly a non-petroleum based synthetic grease, and slip them back on.
Periodically, regrease.
Nov 18, 2023 07:21 PM
PROJECT X
Apr 17, 2015 12:13 AM
1996LT1Z28
Apr 14, 2015 07:15 PM
BadBowtie93Z28
Aug 9, 2002 07:52 AM
Wilson
Jul 21, 2002 05:08 PM
