How do you Front Swaybar?
Old Aug 5, 2002 | 05:19 PM
BadBowtie93Z28's Avatar
Question How do you Front Swaybar?
How do you disconnect the front swaybar? and why do people disconnect it? What do you do? Thanks!
2001 Red Camaro Z28 M6, Hardtop and Cloth Seats
Race Weight: 3,530 Lbs. W/ Me
!FRA,!MAF,Cut-Out, Spectacle Solutions Short Stick
5% Tint All Around, Painted Interior Pieces, Rear CAMARO Fill-Ins,Glass-Tek 4" Cowl Hood, RK Sport Sport Wing,Billet Grille, Clear Corners
Stereo: 2 MTX 6000 10" w/ 4250 D and Pioneer 6300
Best E.T.- 13.065 @ 108.55 W/ 2.28 60'
Best MPH-13.105@ 110.58 W/ 2.25 60' http://hometown.aol.com/zulater01/myhomepage/auto.html
Old Aug 5, 2002 | 05:30 PM
RacinLT1's Avatar
Post
Some guys just unbolt the endlinks and tie it up somehow. Some of the others remove it completely.
It helps the front end rise quicker/higher for weight transfer in drag racing.
I ripped mine off little under 2 years ago and havent seen it since.
Dirk
1997 TA A4
11.251@119.3 1.52 60',7.132@95.39 1/8
The RacinLT1
RacinLT1 pic's
Old Aug 7, 2002 | 03:53 PM
MarkR's Avatar
Post
How well do F-bodys handle on the street with no front sway bar??? I wouldn't think it would be too bad since it's pretty low. I had no sway bar on a coil spring Jeep a few years back & it wasn't bad at all as long as you took it easy in turns.
Mark
95 Formula M6
CC305, 1.6 RR's, ISKY springs, ported heads, CSI wp, Cloyes true roller, 160 stat, MSD coil, MSD 6A, Pacesetter headers, Flowmaster cat back, 4.10's...and a few more mods
My Bird
Old Aug 9, 2002 | 02:49 AM
twistedwedge's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by MarkR:
</font>
My 3rd gen handles fine without it, especially when I had the 16x8 wheels all the way around. 4th gen cars should do fine since they have better suspension than third gens.
1987 GTA- TH400 w/brake, 355, carbed, 11.3:1, TFS twisted wedge heads (non ported), Big Shot NOS, Lunati hyd roller .510/.525 lift 232/242 duration @.050, true dual 3" exhaust, hooker super comp 1 & 3/4" headers, flowmaster 2 chamber mufflers, no tailpipes, 6-pt roll bar strange 12-bolt w/ spool and 33 spline axles, BMR anti-roll bar, BMR LCA relocation brackets, BMR solid rod end panhard bar, PA tubular k-member and a-arms, PA coil over conversion, PA manual rack conversion, Weld Pro-Stars 15X10 w/28X12.5 ET Street out back, 15X3.5 out front
Best ET last year N/A,Stock suspension, on street tires, T56, stock rear end and 4.56's @ 3515 lbs: 12.46@115.1 (1/4) 8.15@90.5 (1/8)
drive it like you stole it!!
Old Aug 9, 2002 | 02:51 AM
Question
How do you disconnect it though? Thanks.
Old Aug 9, 2002 | 07:41 AM
94FBIRD's Avatar
Post
Put the car on ramps. Unbolt the endlinks with a 13mm socket and a 13mm wrench. I don't feel that removing the whole thing makes much difference. It's only 11 pounds. I just do the end links after I had mine off and weighed it.
94 Formula/GTP Stage 2 heads/GM LT4 HOT cam/MAC headers/SLP CAI/1.6 rockers/RandomTech cat/ported intake/58mm BBK TB/CSI electric H2O pump/MTI mail-order tuning/2800 Vigilante
Old Aug 9, 2002 | 07:52 AM
Ken95Z28's Avatar
Post
That's cheaper then me going on diet and loosing 11 pounds
Mine has been gone for some time as well. It does handle different can't take the turns as fast as I use to.
1995 Z28 A4 3.42 Best ET(12.205@109.50) LT4 Hot Cam, 1.6RR's, K&N FIPK, 85mm MAF, Mac Header & Y-pipe, Flowmaster Exhaust, CutOut, Yank ST3500, TransGo Shift Kit, LT1 ScanMaster, CSI WP, M/T ET Streets, 6-point Wolfecraft and Ed Wright Programming
Ken's 1995 Z28
F-Body Fastest List
"Never be afraid to try something new. Remember that amateurs built the ark. Professionals built the Titanic."
bitchinangel01
Jun 11, 2015 10:15 AM
BLK1997Z28
May 1, 2015 12:23 PM
PROJECT X
Apr 17, 2015 12:13 AM
97FormulaWS-6
Sep 11, 2002 11:57 AM
Wilson
Jul 21, 2002 05:08 PM
