Strano Rear Sway Bar with Moser Rear End
A quick question for those of you who have mounted a Strano 22mm Hollow rear sway bar to a Moser Rear 12-bolt: what accessories were required to mount it? It's been a LONG time since I've messed with my suspension...probably why I need to change it all out
but as I recall I had no problems mounting my old stock (or SLP version?) sway bar the first time, although I may have needed longer U-bolts.
I talked to Sam about it and he said that if the stock fits then his will fit, but just wanted to hear others' experiences before I start buying up all the components. Thanks.
but as I recall I had no problems mounting my old stock (or SLP version?) sway bar the first time, although I may have needed longer U-bolts. I talked to Sam about it and he said that if the stock fits then his will fit, but just wanted to hear others' experiences before I start buying up all the components. Thanks.
Well did this the other day, and here are my results: To get the Strano rear sway bay to fit the Moser rear you just need longer/wider U-bolts for the axle and that's it. You could pay $75 for the Spohn piece but I just picked a set up at the local auto parts store for a few bucks. Then use the components that come with the sway bar and you're all set. Hope this helps someone in the future.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
