Strano Rear Sway Bar with Moser Rear End
Old Jan 10, 2009 | 09:37 AM
94ZVert's Avatar
A quick question for those of you who have mounted a Strano 22mm Hollow rear sway bar to a Moser Rear 12-bolt: what accessories were required to mount it? It's been a LONG time since I've messed with my suspension...probably why I need to change it all out but as I recall I had no problems mounting my old stock (or SLP version?) sway bar the first time, although I may have needed longer U-bolts.
I talked to Sam about it and he said that if the stock fits then his will fit, but just wanted to hear others' experiences before I start buying up all the components. Thanks.
Old Jan 17, 2009 | 02:48 PM
94ZVert's Avatar
Nobody, huh?
Old Jan 31, 2009 | 07:49 AM
94ZVert's Avatar
Well did this the other day, and here are my results: To get the Strano rear sway bay to fit the Moser rear you just need longer/wider U-bolts for the axle and that's it. You could pay $75 for the Spohn piece but I just picked a set up at the local auto parts store for a few bucks. Then use the components that come with the sway bar and you're all set. Hope this helps someone in the future.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
8T8IROC
Mar 26, 2015 09:02 PM
87Aerocoupe
Jan 10, 2015 07:27 PM
siguy
Nov 27, 2014 10:07 AM
IgorT.455/406
Feb 1, 2005 06:18 AM
