steering shaft
Old Oct 6, 2007 | 08:54 PM
lt1tealm6's Avatar
steering shaft
my buddy put my steering shaft on and it not all the way down on the on the rack it sitting up like a 1/4 inch when i asked him about it he said there was a ajustment is this true i also have play in steering wheel when driveing down the road thanks guys
Old Oct 7, 2007 | 07:31 AM
lethal93ta's Avatar
the connection on the rack itself it will only go on in one spot the rack has a notch in there for the bolt to slide through.
Old Oct 7, 2007 | 09:54 AM
lt1tealm6's Avatar
thanks so it needs to go all the way down im going to try to get it down today and see if the play goes away in the wheel i also have a bmr k memeber with kook stepped headers could this be why he could not get down all the way
Old Oct 7, 2007 | 10:13 AM
lethal93ta's Avatar
it sits down there, is it on at all, you have to take the bolt out to slide it in place.
Old Oct 7, 2007 | 08:06 PM
lt1tealm6's Avatar
when u put all the way down on the rack the bolt on the top hit the header so now i need to adj it back to wear it was is there a aftermarket one i could get that would work better it is like it needs to be longer
Ericksd
Jan 20, 2016 06:07 PM
colts0455
Sep 27, 2015 01:07 PM
Daluchman1974
Sep 11, 2015 06:12 AM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
rideordie
Sep 7, 2015 08:22 AM
