steering rack leaks
Old Oct 16, 2007 | 07:31 PM
Daniel6718's Avatar
steering rack leaks
found this pic
the fluid is on part 10 dont know if you can take it all apart and replace something or is it more practical to replace the whole rack...then pay to get a front end alignment
http://shbox.com/1/rack&pinion.jpg
Old Oct 16, 2007 | 09:36 PM
MyShibbyZ28's Avatar
It's probably more practical to replace the whole rack. You could install it yourself, they are not hard to take out or put in. Two bolts on the wheels, two bolts through the k member, fluid lines, and the steering knuckle that attaches to the top.
Old Oct 16, 2007 | 11:39 PM
Daniel6718's Avatar
i know its not taht hard...and ive got a spare sittin here but id rather just replace a seal or somethign if thats all i need to do...its just a slight hassel to get it aligned again...and costs money
Old Oct 17, 2007 | 10:48 AM
I've never heard, or seen a replacement part for the rack and pinion before. But I know where you're coming from with the hassel and cost.
Old Oct 17, 2007 | 06:33 PM
Daniel6718's Avatar
well mayb some1 else will chime in
Old Oct 20, 2007 | 09:41 AM
RE AND CHERYL's Avatar
There are no replaceable internal parts on the rack.
Re'
Old Sep 29, 2008 | 02:03 PM
sbca96's Avatar
I have a steering rack leak, and I found that Napa carries a rack seal kit. Has
anyone in the last year (since the last post on this thread) done this? This
leak isnt really bad its not making more than a soda can bottom circle on the
driveway. Other than the leak, the rack seems to work fine. Special tools?
Tom
PS: Its Napa number NPS73615:
http://www.napaonline.com/MasterPage...inion+Seal+Kit
Product Features:Replacement Seal Kit Ensures Factory Fit & Function
Additional Contents:
(8) Rubber O-Rings
(4) Boot Clamps
(5) Teflon Sealing Rings
(2) Retainers
(1) Wire Retainer
(4) Pressure Seals
(2) Bushings
(1) Nut
Fastbird93
Apr 9, 2016 07:01 PM
Scorch1
Jun 30, 2015 11:24 PM
Injuneer
May 15, 2015 08:45 AM
