steering knockle need help asap!
Old Jul 2, 2005 | 10:55 PM
tkiely05's Avatar
got steering knuckle off and cant get it back on. any help is greatly appreciated.
Old Jul 2, 2005 | 10:59 PM
Re: steering knockle need help asap!
Spread the a-arms apart and slip it on the ball joint studs. Not sure what else to tell you. Maybe some more details on what you are doing would help.
Old Jul 2, 2005 | 11:05 PM
tkiely05's Avatar
i just installed long tube headers. now i just cant figure out how to get the knuckle back on because of the tight fit.
Old Jul 2, 2005 | 11:09 PM
69vette's Avatar
i think he may be talking about the joint that attached the steering collum to the rack and pinion..all them i have done went on fine..slide it up on the steering collum part first and thenget the bottom to sit on its spot..you have to have the wheels in the right place as it will only go on one way
You don't mean the steering knuckle, then (your front wheel hubs attach to the steering knuckle). You mean the steering shaft coupler. It is usually a tight fit that just has to be played with to get it back on.
Old Jul 2, 2005 | 11:10 PM
tkiely05's Avatar
sorry for the confusion. thanks for the help ill keep trying.
Old Jul 2, 2005 | 11:55 PM
tkiely05's Avatar
Thumbs up Re: steering knockle need help asap!
thanks 69vette your advice worked slid right on.
rideordie
Sep 7, 2015 08:22 AM
Devinfoote87
Sep 4, 2015 05:52 PM
War Engine
Aug 28, 2015 06:04 AM
asilomar244
Jul 12, 2015 05:53 AM
