STB installation
Okay... Probably a dumb question, but I'll ask anyway...
I just bought a used BMR STB and it didn't come with any installation instructions. So..., is there anything more to it than just removing the nuts from the top of the struts, installing the STB and tightening the nuts back on?
Thanks!
TS
Thanks!
TS
Re: STB installation
One possible problem is the fact that the studs from the upper spring seats, that you need to slide the STB over, are not vertical. As a result, it may appear impossible to fit the brace over the studs... one side will fit, the other won't. I had to loosen the two bolts on one shock tower, in addition to the two studs. Then I jacked the front end, and pulled the wheel down so the studs retracted into the fender. Then you put the STB over the holes, and let the studs pop up into the holes.
Thanks guys! No problems with the installation: removed the nuts, placed the STB over the bolts, tightened the nuts, done.
I took a quick look at their website, but couldn't find that... Duh...
Originally Posted by OBE1 95Z28
1996LT1Z28
Apr 14, 2015 07:15 PM
lbrowne
Aug 22, 2002 06:21 PM
