Squeak
Old May 4, 2009 | 03:56 PM
Red96Lt1's Avatar
Squeak
I'm guessing this is a wheel bearing, but just to make sure. Most times when I take a right turn, I hear a loud pitch squeek from the rear of the car. It's been getting worse. It's usually when I'm making a sharp right.
Old May 4, 2009 | 10:38 PM
SS44Camaro's Avatar
this should probably be in the suspension section. but it is probably either the bushings in the sway bar or control arms, maybe even panhard bar. you could try oiling them up and see if it stops it temporarily and see what you need to replace
Old May 5, 2009 | 01:34 AM
brianswimmer23's Avatar
you might also want to check your brakes. it could be the pad rubbing on the rotor during your turn .
Old May 5, 2009 | 06:13 AM
JooneJune's Avatar
Brake feeler, check your brakes. They may need to be changed...
Old May 31, 2009 | 09:53 PM
briand069's Avatar
If you haven't fixed this yet, do a search for it. Mine did the same thing and it was the caliper bracket hitting the brake rotor. I put a thin spacer in between the bracket and the mount on the axle and the noise stopped. I think it has something to do with wear and the axles move more and force the calipers to move out further.
Old Jun 1, 2009 | 07:33 AM
Red96Lt1's Avatar
Wow, Don't know if I would have ever checked that. Thanks!
Ferocity02
Dec 1, 2003 12:02 AM
Ferocity02
Aug 6, 2003 01:55 PM
camaro98_speed
Jul 31, 2003 03:44 PM
TheV6Bird
V6 Tech
9
Jul 13, 2003 11:54 AM
scoobysnax83
Feb 18, 2003 01:54 PM
