SLP Brake Line Lock ... can this be self installed?
Old May 12, 2010 | 12:01 PM
hozb817's Avatar
Exclamation SLP Brake Line Lock ... can this be self installed?
Just curious to know if installing a SLP line lock would be difficult to do on my own?
Any advice or referals to links for help would be greatly appreciated.
Thank you
Old May 12, 2010 | 02:17 PM
jasonface's Avatar
Mine's not an SLP, but it probably uses the same Hurst Roll Control solenoid. Mine was very easy, 1-2 tops, taking my time. Just make sure the kit has all the prebent lines and you're good to go!
Old Jul 27, 2010 | 09:59 AM
drz28ls1's Avatar
brake lines?
on my mastercylinder, which lines go where? thank you, kurt i have a 1983 camaro, turbo 400 trans, ford 9 rear end 355 ci motor
Old Jul 27, 2010 | 10:01 AM
razor02097's Avatar
Yes the line lock can be installed yourself. It really isn't that hard, and it comes with everything you will need.
I will try to take some pics to help you out.
Old Jul 27, 2010 | 12:27 PM
razor02097's Avatar
Here is where I mounted the line lock unit
The line in the back goes to the line lock unit
The power wire is run to the battery junction
The ground to the switch, the other switch prong goes to ground.
Here is where I mounted the switch
Hope that helps
Old Jul 27, 2010 | 11:33 PM
OBE1 95Z28's Avatar
Thank you
Does this kit come with new brake lines? If not, flaring the hard brake lines after cutting them can be a bit tricky.
Old Jul 28, 2010 | 06:37 AM
razor02097's Avatar
The SLP kit comes with new prebent lines
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jazsun
Dec 29, 2014 12:14 PM
