SLP Brake Line Lock ... can this be self installed?
Just curious to know if installing a SLP line lock would be difficult to do on my own?
Any advice or referals to links for help would be greatly appreciated.
Thank you
Thank you
Here is where I mounted the line lock unit
The line in the back goes to the line lock unit
The power wire is run to the battery junction
The ground to the switch, the other switch prong goes to ground.
Here is where I mounted the switch
Hope that helps
Hope that helps
Does this kit come with new brake lines? If not, flaring the hard brake lines after cutting them can be a bit tricky.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
