SJM ABS delete/line lock kit and tcs removal
Old Jun 2, 2006 | 03:27 PM
always faster's Avatar
Ok i want to cancel and take off my abs stuff(module,wire etc.) and also my tcs stuff(wire,module etc.)
Im going to buy the complete kit from SJM(proportion valve,line lock,prebent lines and flairing tool,etc.)
-I ve found this about the removal of abs:
http://www.pharmacy.arizona.edu/staf...veABSunit.html
-I found this on the tcs removal:
http://www.pharmacy.arizona.edu/staf...veTCSunit.html
-And the install of a proportion valve:
http://www.pharmacy.arizona.edu/staf...PropValve.html
Now that i know how to remove everything does anyone know precisly how to reconnect all the brake lines so that everything work or have any link(with pics).
Also i have found the kit but they ask me if i got 3 channel or 4 channel, since im deleting the tcs module, do i order 3 channel or 4 channel?
Thank you
Old Jun 5, 2006 | 07:01 AM
Re: SJM ABS delete/line lock kit and tcs removal
Bumpy
Old Jun 5, 2006 | 05:40 PM
ss97dml's Avatar
if you have tcs you need a 4 channel.it comes with everything you need,including new lines .i did it on my 97ss and it only took a couple hours.it's a 3 channel and was pretty simple to do.
jj_burchiel
Mar 21, 2015 12:51 AM
squarehead
Jan 15, 2015 07:02 PM
ANDYZ28
Dec 29, 2014 09:13 PM
Queens94z28
Dec 20, 2014 09:11 PM
GA93FORMULA
Jul 24, 2002 11:38 PM
