Should I have welded this part of the SFC to the body?
Old Oct 16, 2005 | 06:45 PM
2QUIK6's Avatar
I'm wondering if I should have welded the rear part of the sub-frame connector to the body...the part that the LCA bolts up to..and also maybe part of the sides where the LCA bolts to?? The instructions only mentioned welding the "pads" to the body..there were 3 "pads" on each side.
Here's a pic of the rear part I'm talking about...its kind of a large gap, but nothing I can't fill in with the welder.
http://hometown.aol.com/onebadwskier...bframe-end.jpg
Here's a pic of the entire underside, the part I'm talking about is almost right over the rear car lift arms.
http://hometown.aol.com/onebadwskier...-underside.jpg
Reason I'm asking is I'm having trouble keeping them from "knocking", I have the bolts as tight as I can get them with the suspension loaded...they were fine at first, but squeeked, so I removed them and regreased them up, and now it doesn't squeek any but it knocks around going over any bumps.
Old Oct 16, 2005 | 08:23 PM
Greed4Speed's Avatar
Re: Should I have welded this part of the SFC to the body?
Yes, it should be welded.
Old Oct 16, 2005 | 10:10 PM
LWillmann's Avatar
I would think that you'd be fine welding the pads, and on the outsides of where the LCA mounts, around where the bracket contacts it.
Old Oct 22, 2005 | 03:35 PM
2QUIK6's Avatar
Cool beans, I welded the end of the SFC up and the knock went away. Thanks all!
Jason Short
Jan 19, 2015 06:34 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
cmdeshon
Dec 12, 2014 10:51 PM
squarehead
Nov 21, 2014 08:02 PM
