shock spacers?
Old Apr 9, 2006 | 09:46 PM
DiabloGT's Avatar
shock spacers?
i was thinking of getting these 1/2" ones all over the car so all the scraping can stop lol, what do you guys think of these that bmr makes?
thanks
Old Apr 9, 2006 | 10:29 PM
FastLt1's Avatar
Re: shock spacers?
I made my own. No problem yet been 6 months.
Old Apr 9, 2006 | 10:33 PM
amean94ta's Avatar
Re: shock spacers?
my only thought is it will compress the shock and take it oou of its travel range in certain situations just my thoughts maybe not
Old Apr 9, 2006 | 10:40 PM
DiabloGT's Avatar
Re: shock spacers?
how do you put them on? and did you like the idea?
Old Apr 10, 2006 | 06:56 PM
DiabloGT's Avatar
Re: shock spacers?
and does anyone know if you can use these in the front and back or only the front?
thanks
Old Apr 11, 2006 | 08:32 AM
Re: shock spacers?
The spacers that BMR makes are only for the front. They work by raising the bottom of the shock, which raises the lower spring seat on the coil-over front shocks. You don't have a coil-over shock in the back, so there's nothing you can do to the shocks to raise the ride height of the rear. You would need spacers under the springs, a thicker upper rubber seat, or do it the right way and go to a coil-over kit for there rear.
Old Apr 11, 2006 | 06:25 PM
DiabloGT's Avatar
Re: shock spacers?
what about an eibach drag launch kit? are those just as good on handling as stock springs? are they ok for the street? and how much do they raise the car by? and whats a coil over kit, how much, and where can you get it?
thanks
p.s. what about adjustable shocks? what do you think of koni? can they raise the height of the back at all?
thanks
Old Apr 11, 2006 | 10:20 PM
Re: shock spacers?
I have the Eibach Drag Launch springs in the back. Raised the back end about 1/2". I haven't noiced any radical changes in street handling, but then my car is really set up to go only in a straight line, so I wouldn't even attempt to drive it hard in the corners.
A coil-over kit puts the rear springs over the rear shocks. With a QA1/HAL shock, that makes the ride height fully adjustable, since you can move the height of the spring seat on the shock body. You can also get QA1/HAL shocks for the front, making the front ride height adjustable.
For a quality coil-over kit for the rear:
http://www.spohn.net/category.cfm?categoryid=1202
"Adjustable" shocks like the Koni's only allow you to adjust the shocks' stiffness, not the ride height.
karpetcm
Dec 16, 2015 09:07 PM
Bigfatrat
Parts Wanted
Oct 16, 2015 04:48 PM
football4life
Oct 4, 2015 07:48 AM
Devinfoote87
Parts Wanted
Aug 6, 2015 05:05 PM
detroitmuscle
Jul 31, 2015 04:21 AM
