SFC problems
Old Aug 5, 2004 | 08:20 AM
Red96Lt1's Avatar
SFC problems
So I put my SFC's on about a month ago, and got my uncle to weld them on. I notice in the instructions that you may have to tighten up the LCA bolts up to 90 ftlbs to keep them from clunking around. Well I have mine up to 135 ftlbs and it still clunks when I hit a bump and when I hammer down. Any suggestions?
Old Aug 10, 2004 | 01:51 PM
Red96Lt1's Avatar
Re: SFC problems
After 1 week I'm bumping it up.
Old Aug 10, 2004 | 02:09 PM
dnovotny's Avatar
Re: SFC problems
I had the same problem with my KBDD SFCs. I had those removed and replaced with SLPs (much better SFCs by the way). The right rear LCA was R+R'ed. On the KBDDs there's a slot surrounding the LCA bolt hole; the LCA bolt hole became distorted once the SFCs were installed. Because of this I could never tighten the right side LCA and would get a clunk and movement. This actually caused some damage to the LCA mount over time. Now it's pretty much fixed, I don't get the same thunking sound or movement but it still binds only on the right rear LCA.
Old Aug 10, 2004 | 02:14 PM
Red96Lt1's Avatar
Re: SFC problems
So what do you suggest for me?
Old Aug 12, 2004 | 02:11 PM
dnovotny's Avatar
Re: SFC problems
Not sure. A good high performance should shop be able to fix the problem but I doubt this is DIY job.
Old Aug 13, 2004 | 10:10 AM
94Zpower's Avatar
Re: SFC problems
Get weld on SFCs
Old Aug 13, 2004 | 10:32 AM
Red96Lt1's Avatar
Re: SFC problems
they are weld on
HarleyZ28
Oct 5, 2015 06:23 AM
87Aerocoupe
Jan 10, 2015 07:27 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
Mykdiver
Aug 13, 2002 05:38 AM
Krab
Aug 5, 2002 12:08 AM
