sfc install ???
Old Apr 24, 2006 | 11:37 AM
knightarooni's Avatar
sfc install ???
first of all has anyone bought the j&m sfc's from hot part? if so you could help. if not try to answer anyway. I bought these and they are weld in only. one end is flat and the other is round. my welder guy looked at them today and said they will not work. then we tried to fit them up there every way possible with no luck. is hotPart.com full of crap or did I get convertible sfc's? or is there any way to make them work?
sorry, I know pics would help but I dont know how to host them.
one end is flat with almost a "box" (this is the end that should bolt in the back) the front end is round with a little plate that should be welded in. if we got the "box" where it was supposed to go the round end was not in any position to be welded.
sorry so long, any help would be appreciated
Old Apr 24, 2006 | 12:42 PM
Z28_95RIDE's Avatar
Re: sfc install ???
You're installing them backwards.
The box (shovel) end goes on the front subframe and the round end with the flat goes along side the rear control arm mount. I have pics btw.
Old Apr 24, 2006 | 03:05 PM
Re: sfc install ???
that makes alot of sense, thank you very much. I will go back tomorrow and get it done. thanks again.
Nov 18, 2023 07:21 PM
HarleyZ28
Oct 5, 2015 06:23 AM
1996LT1Z28
Apr 14, 2015 07:15 PM
87Aerocoupe
Jan 10, 2015 07:27 PM
GA93FORMULA
Jul 24, 2002 11:38 PM
