separating the front coil and shock
Old Dec 31, 2004 | 10:45 AM
crazy_jackalope's Avatar
will this strut compressor do the job needed to separate the coil and shock on a 94 z. It says it compresses most mac strut setups. here is a link http://www.sears.com/sr/javasr/produ...ab=des#tablink
thanks
Old Dec 31, 2004 | 11:10 AM
2001NBMZ28's Avatar
Re: separating the front coil and shock
Autozone will let you borrow a set under their loan-a-tool program if you have one nearby. Looks like that'll work.
Old Dec 31, 2004 | 12:07 PM
I've used the Lisle McPherson Strut Compressor PN 62300 McPherson Strut Tool. The instructions specifically mention it is NOT for spring removal, but it worked fine on the 4th Gen spring/shock assembly. Looks similar to the one you linked, except the clips actually u-bolt to the spring coils, so they can’t pop off, and can’t start to slip around the spring coils. I put the clamps 5 coils apart on the stock spring, and compressed the spring until it fell loose. After removing the spring, I was able to fully decompress the spring, with about one-inch of threads left on the big compressor bolts.
http://members.aol.com/InjuneerZZ/im...otos/shk02.jpg
Old Dec 31, 2004 | 03:06 PM
cool, thanks guys. there isn't an autozone nearby, but it never hurts to have more tools. thanks for the info.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Dec 4, 2014 11:56 AM
