Rusted Top Shock Nut!!!!!!!
Old May 3, 2004 | 12:21 PM
SATANAZ666's Avatar
wELL AS THE TITLE SAYS, Im having a little bit of a hard time taking off the top nut of the shock on the passenger side. Its all rusted!!!! and when it moves it moves along with the shaft!!!! grrrrrrr. Im thinking of using my SAW-SALL and slicing the sahft while the spirng is being compressed... how did you guys get this thing off?????????
Old May 3, 2004 | 12:33 PM
Bone Daddy's Avatar
#1 Use a sawzall w/ a shorter blade and cut just under the rubber mount.
#2 Penetrating liquid and alot of patience.
#3 Nut cracker.
#4 Cut the shaft off flush with the nut, and drill down through the nut till your hear the "pop".
Old May 3, 2004 | 02:25 PM
SATANAZ666's Avatar
HUMM
oK BONEDADDY, WHERE EXACTLY YOU SUGGEST I cut?
I know you said right below the rubber mount, but where....in between the springs???/ the shaft?????
Old May 3, 2004 | 02:57 PM
Bone Daddy's Avatar
You posted about the upper nut... so yes, cut just under the upper rubber mount, (but too low or too long, and you'll cut the body). Or, cut below the nut. NEVER cut the middle of a shock, fluid gets everywhere and it's toxic.
Old May 3, 2004 | 03:04 PM
SATANAZ666's Avatar
sRRY TO Bother you so much bonedaddy, but Can I just cut the shaft?????? you know the metal shinny one under the dust boot???????? also can I use a SAW-SALL WITH METAL CUTTING BLADE??
Old May 3, 2004 | 03:07 PM
Bone Daddy's Avatar
let's put it this way, if you can squeeze a sawzall into a place where you can cut the shaft, go for it. And yes use a bi-metal and fine toothed blade if possible. But for that much cutting, any generic metal blade will do.
Old May 3, 2004 | 03:17 PM
Before you put it under the knife.... errr Sawz-All.... try this. Lock a vise-grip on the shock shaft (not easy, it is extremely hard), then go at the nut with an air impact wrench. Tighten it first, to give you a 1/2 thread or so a running start on backing it off with the impact wrench. When it stops - and it will - tighten again and back off again. I've had luck breaking a couple of them loose that way.
Old May 3, 2004 | 03:28 PM
SATANAZ666's Avatar
WILL A BLADE WITH 24 TEETH PER INCH BE GOOD???
Old May 3, 2004 | 03:36 PM
Bone Daddy's Avatar
It will jump like a mexican car show with 24 tpi, so be careful. But as long as it cuts metal it will "work".
Old May 4, 2004 | 11:08 AM
SATANAZ666's Avatar
inder the knife......erghhhhh dremel
LET ME TELL YOU all that I got that little sucker off!!!
I used a reinforced dremel disk and sliced the hell out of that nut!!!! then i used a good o'l hammer and chisel and put a hurtin on the sliced nut! it came out no problem! I greased everything up put the new shock in and put it back together!
thanks guys for the ideas.......now on to changing and drillin and or using my dremel for the rivets on the upper ball joints...im going to change them too, i MIGHT AS WELL IM IN THERE ALREADY. tHE TIE ROD ENDS AND EVERYTHING WILL BE BACK TO NEW..HEHEHEHEHEH
Old May 4, 2004 | 11:13 AM
Bone Daddy's Avatar
Congrats!
I should have added 2 more options to my post.
#5 Dremel and some patience.
#6 Go medieval on that ***.
Old May 4, 2004 | 11:59 AM
LPEdave's Avatar
By the way, when you install the new shocks, put a big glob of grease over that nut so it isn't a problem the next time..
Dave
Victor Lamb
Aug 26, 2017 02:52 PM
PublicEnemy1
Apr 7, 2015 12:21 PM
KYWes
Apr 3, 2015 07:59 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
