reverse wheel hop????
MY 02 SS tires hop when im going in reverse. the car is all stock .. only does it in reverse and i took it to my dealer and they don;t know why and only said dont go to fast in reverse. But they did replace my power steering rack but now it makes a thump when i trun to the right.. dont know wut might be wrong with that...
Re: reverse wheel hop????
The suspension is designed to slightly lift the chassis on the launch (based on the "instant center" of the suspension). In reverse, the suspension will lift the axle and basically do the opposite. Do not do burnouts in reverse in these cars. Wheel hop is bad and can/will break things.
Why would you be doing burnouts in reverse? Don't you feel like an idiot? If i saw someone doing that, i'd point and laugh. Basically, the answer to your problem is stop driving like that.
someone told me you shouldnt do reverse burnouts because the angle of the teeth on the ring and pinion gears can't handle a lot of stress rotating the opposite direction (not that anything in that dinky 10-bolt can handle alot of stress regardless
if your not accelerating hard and its happening you have a problem. I go fast in reverse (not mashing the gas fast) and have zero wheelhop. i drive better in reverse then a lot of people do going forward
its fun to freak people out. maybe something in your suspension is binding
your either giving it too much gas in reverse or its some problem i never heard of
) if your not accelerating hard and its happening you have a problem. I go fast in reverse (not mashing the gas fast) and have zero wheelhop. i drive better in reverse then a lot of people do going forward
wytblur
Aug 5, 2002 02:03 PM
