removal of rear bolts on stock torque arm??
I just dropped the tranny for a Mcleod clutch install
And when I tried to disconnect the torque arm near the rear where the two long bolts are i couldn't break them loose. I tried using a breaker bar and air tools, but I didn't eat my wheaties this morning though
Is there any trick to getting this tourque arm disconnected in the back? Thanks
Re: removal of rear bolts on stock torque arm??
Yea, tried that. I'm stumped?? I don't need it to come off right at this moment but in the future when I replace the torque arm I'm going to need those bolts to come loose. Thanks
Wow, the only other thing I've done before is soak it for 24 hrs. Make sure there is no oil, grease, or other road grime on the threads of the bolts. It will make the WD-40 harder to "creep" up into the threads. I would clean the threads with alcohol or something. Then I would try spaying it with WD-40 a couple times in 24 hours, then try it again.
Try WD-40 first. Then you better go back and eat your wheaties because you'll need the brute power to break them loose.
I used to have problems breaking things loose, but after wrenching under the car for the last couple of years, every bolt WILL come out. In one piece or several, but it will.
I did the rear just the other weekend. All I used to break those two loose was the wrench and a piece of ~20" pipe as an extention. That pipe has been a lifesaver many many times.
Yep, think that I just need to let her sit for a while with some PB Blaster or some WD-40 like you guys said...and hit the gym while it soaks!!
Thanks for the help
Thanks for the help
Thanks for the help
Thanks for the helpHeat it till it is dull cherry red and let it cool. Spray a little PB blaster on it and it will come loose.
I changed the whole suspension on my car, heat was my best friend on the job.
Z28
It might sound stupid but make sure you dont have any tension on those bolts. If you are half way through getting that tranny dropped you probably added some pressure to those bolts.
Just a thought...
Just a thought...
Originally Posted by Red96Lt1
If you heat up the bolts, I would replace them since you are tempering them and they will become brittle.
To temper most common steels you would have to quench them in oil or water.
Also the alloy must have enough carbon or other alloy elements to even take a temper.
It is more likely that the bolts will be softened (anealed) rather than made brittle. I would expect them to be grade 5 or softer mild steel bolts.
I would get them out and look at them carefuly. If the shank of the bolt is pitted from rust and the threads are in bad shape, I would order new bolts and nuts. If the bolt looks ok, I would just buy or order some new nuts.
Don't bother trying to heat with propane, it is a waste of time and money. I have done it, buy the MAPP torch.
Z28
Heat...good idea. I totally forgot about that. I have a propane torch that I'll try before making the trip to Wally World. Thanks.
Z28
Thanks everyone for the great advice!
Getting her all put back together now after the Mcleod S/T install. I can't wait. The break in period is going to be torture.
Heading out to Wal-mart to check out that MAPP Torch. Thanks again.
Mikes 1994 z28
Nov 25, 2014 02:00 PM
slothgrant
Aug 22, 2002 03:01 PM
