relocation brackets...bolt in or weld on ?
Re: relocation brackets...bolt in or weld on ?
Honestly everyone on here will either tell you to just buy the weld in, OR buy the bolt in and tack weld them after you bolt them in. Ive had mine on for over a month, only bolted in, and as long as they're torqued to correct specs, they arent going to move. Bolted is fine, but welded is always going to be better...
Originally Posted by red96z
i heard these help now which should i get ? is the only difference the bolt on is not really permanent?
RUENUF
Mar 13, 2016 03:37 PM
