relocation brackets...bolt in or weld on ?
Old May 3, 2006 | 05:11 PM
red96z's Avatar
i heard these help now which should i get ? is the only difference the bolt on is not really permanent?
Old May 3, 2006 | 05:16 PM
93redBirdMan's Avatar
Re: relocation brackets...bolt in or weld on ?
Honestly everyone on here will either tell you to just buy the weld in, OR buy the bolt in and tack weld them after you bolt them in. Ive had mine on for over a month, only bolted in, and as long as they're torqued to correct specs, they arent going to move. Bolted is fine, but welded is always going to be better...
Old May 3, 2006 | 05:18 PM
Z95m6's Avatar
Bolt on's won't work with aftermarket rear ends. I have bolt ons and am happy with them.
Old May 3, 2006 | 10:22 PM
Bud M's Avatar
The other difference is that you can install bolt in yourself even if you can't weld.
Old May 3, 2006 | 10:52 PM
Your sig shows you probably launch hard. Weld-ons would likely be the most reliable for you, IMO. BMR told me a long time ago that bolt-ons (like I have) are fine until you are cutting some really low sixtys. I don't race my car, so the bolt-ons are fine for me. Like was already said, you can also tack-in the bolt-ons later.
Old May 3, 2006 | 10:57 PM
Honda Hunter's Avatar
I had my bolt ons welded.
RUENUF
Mar 13, 2016 03:37 PM
football4life
Oct 4, 2015 07:48 AM
4586
Aug 22, 2015 01:09 AM
4586
Aug 18, 2015 07:08 AM
Boss002
Jul 24, 2015 10:47 AM
