relocation bracket for lca's
Old Nov 27, 2005 | 07:41 PM
jjtz28's Avatar
im trying to get some info on relocation brackets for my lca's.on other sites somepeople saythey are to level out the lca's...other people say they are to put the lca's at an angle.could someone help!
also some pics of it installed!
thanx
Old Nov 27, 2005 | 08:59 PM
Greed4Speed's Avatar
Re: relocation bracket for lca's
The put them at the angle that you lose when you lower your car. When you lower your car, the angle flattens.
Old Nov 27, 2005 | 09:38 PM
For straight line traction purposes, you want the body end of the LCA to be located higher than the axle end of the LCA. When you launch hard, you want the front of the LCA to lift the body, causing the back end of the LCA to force the tires into the pavement. If you start with the LCA's "level", as soon as the body starts to squat on launch, the LCA pushes the body down farther, and the reaction at the axle end unloads the tire.
Old Nov 28, 2005 | 02:53 PM
OBE1 95Z28's Avatar
Road racing experts (like Sam Strano) suggest that the best handling position for the LCAs is parallel to the ground. For drag racing Fred did a great job in the post above to describe the physics.
Old Nov 28, 2005 | 05:12 PM
jjtz28's Avatar
thanx... i think im gonna order them,i just dont know from where yet
Old Nov 28, 2005 | 08:37 PM
hotpart's Avatar
Former Vendor
The problem you will have with running them on a road race track or autocross is the potential for brake hop. Anytime you increase your anti-squat you increase the chance of brake hop. If you can increase your anti-squat without inducing the brake hop you will be able to accelerate out of a corner better.
Old Nov 29, 2005 | 08:47 PM
slomarao's Avatar
So do you guys think relocation brackets will help a non-lowered car hook up better. I was under the impression that they would, but the guys at ls1speed told me different. They said that it wouldn't do anything, he told me to get a TQ arm if i wanted better 60fts.
Old Nov 29, 2005 | 09:19 PM
jjtz28's Avatar
my car is lowered...but i do understand what you are saying.i've allready been told once i get the brackets i should get the torque arm also!
Old Nov 29, 2005 | 11:07 PM
The LCA relo brackets will improve straight line traction, even if the car is at stock ride height. The back of my car sits a little higher than stock with the Eibach Drag Launch springs, and the LCA brackets were the key to getting rid of wheel hop. I've also seen them make a major improvement in a 30th SS convertible, at stock ride height, that eventually ran 8.60@160+ MPH.
Nayr
Mar 3, 2023 08:34 PM
13qtr
Oct 28, 2016 08:11 PM
War Engine
Sep 18, 2015 07:28 PM
realistyc
Jul 28, 2015 07:32 PM
Boss002
Jul 24, 2015 10:47 AM
