red BRAKE light in dash
Old Oct 17, 2006 | 09:47 PM
JMiller's Avatar
My brakes lately have been feeling pretty weak. Today I was coming to a red light, and I'm putting more pressure than usual to stop, when suddenly the pedal goes all the way down with a sudden click, and the red brake light shows up. I checked the fluid, only to find it was almost empty, so I bought more tonight and filled it up. No change though. The light is still on, and the brakes are still weak. Anyone?
Old Oct 17, 2006 | 09:53 PM
davidarel's Avatar
Re: red BRAKE light in dash
You need to bleed the system. There is a shuttle valve in the ABS module that tripped the light.
Old Oct 17, 2006 | 10:34 PM
If any air did get in the system, yes, you need to bleed it. If the light stays on after bleeding, stand on the brake pedal hard until you hear another click and the light goes out. The pressure differential switch will then be reset.
Old Oct 18, 2006 | 04:14 AM
throb's Avatar
Make sure the "click" you heard wasn't a flexible brake hose (leading to the calipers) breaking. If so, it's going to be leaking fluid (big time) and will need replacement.
Old Oct 18, 2006 | 02:05 PM
If you found the master cylinder was "almost empty", take the time to inspect the entire system for leaks.
squarehead
Jan 15, 2015 07:02 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
AW/whiteZ-28
Aug 27, 2002 12:53 AM
AW/whiteZ-28
Jul 25, 2002 04:09 PM
