which rear sway bar endlinks?
I had to cut off my old rear swaybar endlinks when I removed my rear recently to install the new 9". I bought a pair of Energy Suspension endlinks to replace them but I wasnt sure if I got the right ones. I got the same set that they have listed for the front sway bar since they didnt list one for the rear. Is that correct or is there a different set for the rear. I've got some play in the rear now when I get on the car hard now and I wonder if these links have anything to do with it. Thanks.
Yes I got them and they are on the car. I cut up the old ones pretty bad removing them since they were siezed and didnt keep them to compare when I got these. The back end just seems to get loose when I get on it now after installing the new rear, the car wants to jump to the side when I punch it, thought this might have something to do with it. I also know I need an adjustable panhard rod, I'm still using the stocker. The aligment of the rear is a bit off, it sits about 1/2 or more to the left than the stock rear did. Maybe its just the panhard rod that will fix this movement.
You could just be feeling the way a different differential works. It wouldn't be the end links, but yes the stock Panhard rod with rubber bushings certainly is the thing allowing the rear to shift left/right.
Dave
Dave
Yeah, I figured this rear would feel different, just didnt expect the amount of movement I was feeling in it. I ordered a BMR adjustable phr today, I thought that probably had more to do with it too but I wasnt sure if the endlinks were part of the problem too. Thanks for the help guys.
carguyshu
01-22-2017 11:19 AM
