Rear spring mount
Old May 10, 2015 | 06:37 AM
KYWes's Avatar
Rear spring mount
Ok, so I was doing some work on the back of my car and noticed that there is no rubber isolation mount under the rear coil springs of my car. It looks like the springs are just fitting around a small raised piece on top of the axle.
Is this right or have I lost a mount for my springs?
Old May 10, 2015 | 06:47 AM
FirstYrLS1Z's Avatar
Re: Rear spring mount
yes,it is right,the upper end of the spring has the isolation mount.
Old May 10, 2015 | 10:47 AM
You can download a free copy of the 94 factory manual, good reference for questions like this:
LINK: 4TH GEN SERVICE MANUALS - Firebird Nation
Or, if you don't want to do that, Nalley has the factory parts diagrams:
SUSPENSION/REAR. Fits: Camaro, Firebird, FORMULA, TRANS AM | Nalley Buick GMC Brunswick
Old May 10, 2015 | 01:55 PM
KYWes's Avatar
Good to know. Thanks
Old May 12, 2015 | 04:04 AM
KYWes's Avatar
I'm going to replace the rear springs on my '95 Z28. I see they're not coil overs. Any tips or gotchas I should know? Is it as simple as compress the spring, remove and reverse with new spring?
Old May 12, 2015 | 05:29 AM
Don't even need to compress the spring. Support chassis by jack stands, unbolt lower shock bolt, lower rear axle slowly. Springs will fall out.
Old May 12, 2015 | 06:19 AM
KYWes's Avatar
Excellent! I'm replacing the shocks so I can do it all at once.
HectorM52
Jul 30, 2017 11:46 AM
Jazsun
Dec 29, 2014 12:14 PM
wytblur
Mar 2, 2003 03:40 PM
