Rear shock removal
Old 07-23-2005, 02:30 PM
NZ12'S's Avatar
Rear shock removal
How do you remove the top end of the rear shocks on my 99 z???
Thanks in advance.
Jay
NZ12'S is offline
Old 07-23-2005, 08:36 PM
Shempy's Avatar
Re: Rear shock removal
Either you remove the carpet in back, or you find the perforations in the carpet behind the back seats. If you cut the perforations, you'll find the top of the shock underneath the flap. Then you put an open ended wrench on the bottom nut, and brac preferably a ratcheting wrench on the top nut, and then a hex wrench into the top of the shock and begin working on the ratcheting wrench while holding the hex steady.
Hope that helps!
Shempy is offline
Old 07-24-2005, 11:45 AM
Keliente@pcmforless's Avatar
I just put the rear seats down and pulled up all the carpet...then you can see the foam pads..remove those and the top of the shock is underneath.
Keliente@pcmforless is offline
Old 07-25-2005, 11:29 AM
NZ12'S's Avatar
thanks guys, it's a done deal!
NZ12'S is offline
Old 07-25-2005, 12:27 PM
Shempy's Avatar
Shempy is offline
10-31-2016 11:09 AM
4586
01-03-2015 07:22 PM
siguy
11-27-2014 10:07 AM
squarehead
11-21-2014 08:02 PM
slothgrant
08-22-2002 03:01 PM
Quick Reply: Rear shock removal
