Rear shock removal
Re: Rear shock removal
Either you remove the carpet in back, or you find the perforations in the carpet behind the back seats. If you cut the perforations, you'll find the top of the shock underneath the flap. Then you put an open ended wrench on the bottom nut, and brac preferably a ratcheting wrench on the top nut, and then a hex wrench into the top of the shock and begin working on the ratcheting wrench while holding the hex steady.
Hope that helps!
Hope that helps!
10-31-2016 11:09 AM
squarehead
11-21-2014 08:02 PM
slothgrant
08-22-2002 03:01 PM
