Rear brakes squeek - Stop when I pull the E-Brake?
Old Jul 16, 2007 | 09:39 PM
  #16
wrd1972's Avatar
Originally Posted by 5H9D0W
Maybe you can give a little more description on what to grind off the caliper. I didn't really notice a wear line on the rotor and I didn't see a spot on the caliper bracket that needed to be grinded.
DONT grind the caliper, you want to grind on the mounting bracket.
Okay, I think I may have figured out what you guys are talking about but a little better description wouldn't of hurt.
I cant do any better than this:
The best thing to do is grind in the inside areas shown by the arrows (edge next to rotor) and skip the washers. I would remove a 1/16" or so. If you look closely you should clearly see the signs of the rubbing. If you have the true rotor rubbing squeak I will guaretee this is the fix, or no money back
Gtpguy
Jan 26, 2015 04:50 PM
Jazsun
Dec 29, 2014 12:14 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
bossco
Nov 29, 2014 10:18 AM
