Rear brake squeaks!
Old Aug 18, 2004 | 04:58 PM
matts_z28's Avatar
Rear brake squeaks!
I just changed my rotor and pads in the rear. Now my drivers side rear squeaks like crazy only when I turn left. It squeaks also when I am taking a corner at a fast speed. Do I have a bad rotor?
Old Aug 18, 2004 | 05:05 PM
sabre81's Avatar
Re: Rear brake squeaks!
you may have bad rotors. Two things for ya to do. Did you use disc brake quiet? Also my caliper bracket was actually touching my rotor causing a sqeak. ALl i did was stick a couple washes between where the caliper mount bolts to the axle. Basically check to see if the rotor is rubbing anywhere, and use disc brake quiet made by permate.
Old Aug 18, 2004 | 06:32 PM
Steve0's Avatar
I have the same problem after my brake pad and rotor install about 2 weeks ago. Same exact thing, I'd turn left and squeak. Then itd get to squeaking when i applied the brakes, and sometimes when I took off.
I think its because I used cheap pads. I went to NAPA and all they had was a $20 pad and a $70 pad. I decided to be cheap and try the 20 dollar ones. Now, not only do I think they are the cause of the noise, but they dust horribly! I should have went quality like I did on the front.
I am going to swap my rear pads sometime this week. If you havent found a solution by the time I do it, I'll let you know if my pad swap did the trick.
Old Aug 18, 2004 | 09:01 PM
sabre81's Avatar
i got the carbon metallic ones from autozone(semi cheapos) and their perfect.
HarleyZ28
Oct 5, 2015 06:23 AM
Jlo
Apr 3, 2015 10:32 AM
Jazsun
Dec 29, 2014 12:14 PM
trefidy
Jul 26, 2002 03:40 PM
