Panhard Rod??
Old Jun 9, 2012 | 01:05 AM
mikeZ2878's Avatar
Question Panhard Rod??
I can't decide which one to get adjustable or non adjustable?? Car is not lowered butt plan on lowering in the future.
Old Jun 9, 2012 | 06:16 AM
Re: Panhard Rod??
The adjustable rod moves the body from side-to-side relative to the rear axle assembly. Is the body centered correctly over the rear axle now? When you drop the chassis, the body will move very slightly to the passenger side, relative to the rear axle assembly.
Old Jun 9, 2012 | 03:23 PM
Re: Panhard Rod??
If you even think you will lower it later, get the adjustable. Better that, then having to buy two of them. Some stock cars are not completely centered, anyway.
Old Jun 24, 2012 | 10:10 PM
HardcoreRM125's Avatar
Re: Panhard Rod??
My car is a convertible ... I don't know if that has anything to do with it, but mine was out over 7/16", just a cunnair shy of half inch. If you looked closely, from behind, you may even have been able to see it?
Anyways, that is on stock springs stock rideheight.
I got an adjustable one, loaded the suspension, and busted out my plumb bob and haven't looked back. I got her to within 1/32" and I figure, if your within a 1/16th, thats good enough for a street car.
Oddly, it takes very little adjustment to really move the body. I think turning the PHB 3 or 4 complete turns is all it took to swing the body back over the axle centered properly.
Joe
Old Jul 7, 2012 | 01:48 PM
OBE1 95Z28's Avatar
Re: Panhard Rod??
As stated above, a stock ride height car can be off with side to side location. An adjustable bar can correct this.
Old Jul 10, 2012 | 01:48 PM
UMI Performance's Avatar
Former Vendor
Re: Panhard Rod??
We are very careful when selecting adjustable vs non-adjustable LCA's and probably sell a 50/50 mix of both. But for Panhard Bars, adjustable is by far the most popular item. A nice double adjustable poly/poly is a great and inexpensive investment.
Panhard Bars : UMI Performance, Inc.
Let me know if I can help you select.
ramey
RUENUF
Mar 13, 2016 03:37 PM
football4life
Oct 4, 2015 07:48 AM
Z Power
Sep 19, 2015 11:19 PM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
