panhard bar/lcas install
Old Apr 28, 2007 | 04:33 PM
krazykorean35's Avatar
im bout to install an umi non adjustable panhard bar and some lcas tomorrow and was wondering if anyone had any advice for this install. never dont any suspension work before, and im using installuniversity's install guides...thoughts/?
Old Apr 28, 2007 | 05:05 PM
2000GTP's Avatar
Its a pretty straightforward job. However, by soaking all of the old bolts with PB Blaster and having a breaker bar handy should make the job go smoother. Also, for the LCA install, it helps to put the car up on ramps and then raise the rearend with a floorjack. Use the floorjack to make adjustments in the rearend height in order to snake the bolts thru the LCA holes.
Old Apr 28, 2007 | 05:20 PM
thanx4 the tips, would u suggest the differential as the lift point for the lca install?
Old Apr 28, 2007 | 05:57 PM
JimboManJones's Avatar
Thats where I lift my car from, also make sure the supension is loaded when you do the final tightening of the bolts.
Old Apr 29, 2007 | 01:23 PM
2000GTP's Avatar
No, I would raise the rear of the car and then support it with jackstands placed under the chassis rails. Then use the floorjack to raise or lower the rearend to get the right angle so you can slide the LCA bolts through the holes.
Old Apr 29, 2007 | 09:54 PM
just finished doin the lcas...did the phb this morning...used the spots that gtp2000 suggested for the jackstands and raised and lowered the diff with the jack. 1st lca was a bitch but the 2nd one was easy...didnt use any locktite tho...feels good downshifting and feelin less wheel hop tho!
Old Apr 29, 2007 | 11:00 PM
jamilz28's Avatar
a breaker bar will get the bolts off easy
Old May 1, 2007 | 02:43 PM
Fierotom's Avatar
are the LCA's from UMI too?
are you happy with it?
I want to buy the same set, but I'm not sure....
(see my tread please http://web.camaross.com/forums/showthread.php?t=518325)
Old May 10, 2007 | 10:44 PM
solarofthesix
Guest
Posts: n/a
hotpart.com lcas pwn!
Old May 12, 2007 | 11:08 PM
ls1powerz28's Avatar
Whats the difference between getting the adjustable lower control arm and the non adjusable rear control arms?? Is it worth getting the adjustable and also is the non adjustable that much better then the stock. Also do I need the LCA Relo Brackets?? I do not have my car lowered, and I dont plan on it, so do I need them too? Thanks
Old May 14, 2007 | 03:06 PM
ConElite's Avatar
The only difference in adjustable and none-adjustable is it gives you the ability of adjusting the Thrust angle. LCA relocation brackets are always a good idea even if you dont lower the car. That will help eliminate all wheel hoop. I have the non-adjustable Panhard (which I wish I got the adjustable one) and the single syphirical rod end control arms and Im very happy with how my car slams the alxe into the ground when I launch.
Old Jun 1, 2007 | 01:26 PM
00ls100's Avatar
just a question, with all the suspension parts, the single adjustable can be adjusted while they are on the car right??
Old Jun 1, 2007 | 02:56 PM
2000GTP's Avatar
Yes, the adjustable parts can be adjusted on the car.
Old Jun 1, 2007 | 03:16 PM
00ls100's Avatar
k, thank you 2000GTP. Now I can start spending money.
Old Jun 1, 2007 | 05:02 PM
Check on the way your vendor uses the term "single" adjustable.
Typically, a "single" adjustable only has threads on one end. You need to remove the bolt and drop the arm out of the bracket to adjust it. "Double" adjustable has either a dual-threaded adjuster in the center, or opposite hand threads on both ends to allow the adjustment to be made without unbolting anything.
Adjustable LCA's can also be useful for movnig the entire axle assembly forward or backward, to maximize clearance for large slicks.
"syphirical"..... isn't that an STD ? Spherical.
Nov 18, 2023 07:21 PM
HarleyZ28
Oct 5, 2015 06:23 AM
1996LT1Z28
Apr 14, 2015 07:15 PM
Trevor98ramair
Jul 31, 2002 02:43 PM
