No Brake Pressure!!! Dangerous Stuff!
Old Feb 28, 2005 | 11:33 PM
Mac_G_Flip's Avatar
Arrow No Brake Pressure!!! Dangerous Stuff!
Hey
I just acquired a '97 Camaro Z28 with an Auto Tranny and I was baking it into my garage and noticed there was no brake pressure, had to use the E brake. I tried filling the BRake Fluid to level but every time i had someone pump the brakes, it sounded like a 'squishing' noise. ::::Prior History:::: Got into a Medium Front End Accident and Side Swipe :::: If I had to guess these two are related some how. Any insight on what i should check? or anyone have the same problem? Any input would help.
thanks
chris
Old Mar 1, 2005 | 10:08 AM
NJSPEEDER24
Guest
Posts: n/a
Re: No Brake Pressure!!! Dangerous Stuff!
Get the car up and check for leaks
Old Mar 1, 2005 | 11:23 AM
97FormulaWS-6's Avatar
Either leaks or a bad MC, my MC failed without warning on the highway, no breaks at 65 sux....
Old Mar 1, 2005 | 12:10 PM
NJSPEEDER24
Guest
Posts: n/a
Yeah I figured he'd know to check the master cylinder....
On another note, no brakes after your master cylinder failed? They have dual master cylinders for that very reason..How old was the car?
Old Mar 1, 2005 | 03:28 PM
It was on my 97....
yea, but duals don't help when the o-rings in the MC go, and pressing the pedal does nothing except move the piston and the fluid all goes around the piston...
Old Mar 2, 2005 | 02:31 PM
Mac_G_Flip's Avatar
Arrow Re: No Brake Pressure!!! Dangerous Stuff!
That what I figured. Either leak or a Bad master cylinder. They have some used ones on eBay for a decent price. If its not the master cylinder and its a leak, whats the worst case scenario as far as the leaks go?
Old Mar 2, 2005 | 04:11 PM
Typically if it's leaking, it's just a rubber line that's easially replaced. Most of the stuff in the brake system isn't that expensive and can normally be replaced fairly easially.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
Jul 4, 2005 05:00 PM
kclarson
Aug 22, 2002 04:04 PM
